Help, Running Issues
(In Topic #205493)
Please see attached video and any help would be greatly appreciated.
1. Ignition timing
2. Mixture
3. Idle speed
and oviously other components such as those of the ignition system, should be in good condition too. Hesitation during starting can be due to too much ignition advance, but its normally just poor battery condition and/or wiring.
mark1gls said
Just watched your video and the engine seems not to turn over fast enough upon crancking, how old is the battery and is it fully charged?
I noticed that as well, mine sounded exactly like that when I adjusted the timing "by ear" and found I had advanced i way too much. It also did that when I had a couple of HT leads crossed. Either time though, it also ran rough whereas Mattrix07's engine sounds like it's running ok. I reckon the injectors are letting through when the engine has stopped and filling the cylinders.
The smell is as you say running rich, get it tuned by someone who knows what they're doing (it's simple to get a 3mm allen key, do you trust yourself? - i've had issues with mine - in the engine block forum 'cold start splutter for 20-30 seconds' came down to the WUR (working fine electronically but the inside was leaking, seal had gone - serviced this myself, cleaned & got a new Viton rubber seal) & fuel pressure. Also the rotor arm was shot, replaced with Bosch Dist. Cap, Rotor arm & leads after this was done i got it tuned as it was smelling (had timing checked prior to my 'issues') Cleaned out Air system, Idle valve, took off hoses & cleaned through, FD, Air Meter sensor, had a service (last year) Made sure all the details were done so the Tune was the last thing, now responsive & good MPG.
Last edit: by Deandubya
^^^This (and I said similar in my earlier post
#1538523)
Setting mixture by smell, or indirect means such as revs dipping when set at the too-rich or too-lean stage, is at best a very rough technique for getting it into the right ballpark.
It needs to be set properly, using a gas analyser which can measure the CO.
