help required, can someone point me in the right direction
(In Topic #225228)
I have a mk1 Caddy 1.6 petrol.its a bit of a frankenstien i think
firstly the brake compensator seems to have gone, Ive been trying to source a replacement part but not having any luck. I have found some space info that a mk2 compensator can be adapted to fit. if this job has been done could someone point me to the thread so i can learn what to buy and how to do it.
the previous owner also installed a 5 speed box. now when i was under the car i found the plate with the numbers 4T 27060 with 2 underneath. i like the idea of this box but its been bodged. the linkage is utter utter urine. I have seen some kits but id like to talk to someone who has done this job to ensure I'm buying the correct parts. further to this is looks like the correct gearbox mount has been installed.
any help would be much appreciated. if any other information is required just ask and ill try grab it !
thanks
4T gearbox is the one with a big 5th gear so low revs at motorway speeds.
Gear linkage guide to have a read, you need to click on the link at the bottom of the page to see the next page..
Gear Linkage Change (Page 1) - The Mk1 Golf Owners Club
As sometimes you just need to replace the bushes near the gearbox and not mess to much with the gear stick.
Sometimes you just need this type of kit.
https://www.ebay.co.uk/itm/VW-GOLF-Mk1-Mk2-GEAR-SHIFT-LINKAGE-BUSH-REPAIR-KIT-Gearshift/192972712611?fits=Model%3AGolf&epid=1227473557&_trkparms=ispr%3D1&hash=item2cee11eaa3:g:EXoAAOSwYB5dG4C5&enc=AQAFAAACcBaobrjLl8XobRIiIML1V4Imu%2Fn%2BzU5L90Z278x5ickkDZTx3%2BuyOyBvPDFejxw2d2OoA7SlhXEyWpELYbgC9W4JYRz5xGvCNP3EhIOeyxeBIJwx%2BDpWFajCaM37b%2FHcoMKvJnhqKqMts3xq7zeuMp0bkXk7z4G5pDU36SzlJUEW%2FumXbr5H34okX6NpJB7mSN1nRV7MAjIiN1w6czc%2BF2OHc1j3iMj3dA6i%2Bh2vXIhr8IZ9EzKnWzYbvHRpmHLyCB6JXt5cnh4SQ0RmUmD2kpyltpmGFTx30LUUgyCXf099cooWotIFmTesYgPtYa8U%2FiFQpaXbBr8cvjCgpMhSr1adk2fRTlcOCDDvJciAHExenbJaB3KkDlIysRnpeYtIYmglgfBbZXw6AB0pcPtmdVk1DL4q4cF9oPY05diOug7yegKOeTyhCk7ILDzrrIA9T0GhDOGAyQkGRQxVZUXlkiT35V7La6sC4H61WyR3PGap1ePt2%2F3b%2FCcvH7GkFvWs5O%2Fw1eSWXPigY%2FhzsIiXJ6ccSTHOSZUi55xP1oaRQkJL%2BxiVwY9eH%2FAaiyw8KKAPiHdha%2F%2B33G5AZhQT9dZkRNL477ZlJApwr5x5UDMH7ZfCS1i3WS6jP9nokS5P0HquNGfNESJklDLJPZq6EopA%2BVnTO2TMEvrA56fCkWTz0NDqqwYASlX5Jah0sMDCmz0VgCZ60wyNHDn%2BiF1NDXfsUNGTeJH8MW9GvA7FZ1Q7KZp6%2FGksyFBssoMgiWneXiIIVv9PcFRUc7Hpe%2BGXRSC74yQgspUfXVRO9zV2rGs%2F%2FAiRGWz%2FCeQG7FpRTYex7osBeg%3D%3D&checksum=19297271261107863e98fe8e43a782075e9f1a0908e4
Or you may need to do the whole lot or somewhere in between as there's lots of kits out there.
https://www.ebay.co.uk/itm/VW-GOLF-MK1-CADDY-SCIROCCO-GEAR-LEVER-REPAIR-KIT-5-SPEED-A1286/192457669910?hash=item2ccf5efd16:g:GJgAAOSw5ZtahX9j
https://www.ebay.co.uk/itm/Gear-Shift-Repair-Kit-New-For-5-Speed-VW-GOLF-MK1-CABRIOLET-CADDY-SCIROCCO-JETTA/392817930397?epid=24003022329&hash=item5b75c5f09d:g:jJEAAOSwq1JZMw9v
