HELP ON REPLACING BLUE FULL BEAM WARNING LIGHT
(In Topic #230903)
the full beam is working perfectly. Any advice would be fantastic, thanks
The other piece of advice I have for you is to "plump' your connector and add an addition ground to the clusters main connection as you will have a lot of less flakier things happen.
Improving your Cluster Connections and ground. | Volkswagen Owners Club Forum
I would check the blue/white wire on pin T14/9 on the cluster to verify that you are getting a positive voltage there when you flash the high's as if that isn't there then your issue isn't with the bulb. You can also use a 9VDC battery with the Positive on pin 9 and the negative on pin 2 (brown) and once connected the bulb should flash as if it doesn't then you have a blown bulb.
Alps 1992 Rivage Green, 1991 Rivage Blue (SOLD), 1986 GTI convertible White (SOLD)
