Heater problem
(In Topic #207741)
Looking for some advise, my heater don't work when turning the switch so I have removed the cover in the bulk head. Fan is spinning freely and I can get it to work if a push hard on one of the terminals from inside skule. The terminals are on tight so could this be a faulty motor?
if still nothing jump the terminals on the fan direct from the battery, brown wire is the earth the others are the 3 speeds
Make sure the Brown wire on the connector is ground and isn't fried, f it is you can take it to any good Earthing point using a Insulated Spad connector and a Screw in to the fire-wall.
If you use a insulated male/female spad, you can then easily remove it in the future.
