Have I set the timing correctly?
(In Topic #210919)
92 Mk1 GTI Cabriolet, previously converted to KR16v on motorbike carbs. ran ok but engine was well worn when I bought it so fitted replacement.
Now Timing how I have it is -
Bottom crank pulley, marks lined up at top TDC
Cam pulley lined up at top TDC
Piston one is at TDC
Flywheel is on TDC (not the 6 BTDC)
The distributer hasn't got a notch, but where all above is at TDC the rotor arm should point to lead no. 1… Yes???
Rotor arm turns forwards (anticlockwise when looking from distributer side)
Lead 1 where rotor is at TDC, then lead 3, 4 and 2
Please please confirm I have all this correct as it just won't fire on no. 3 and 4..!
Wilson
I never use the pulley marks.
I align the Crank using the finger on the transmission.
I align the Cam so the dimple on the back is even with the Valve cover tin (not rebar) or on a 90 that is Digi to the 0 mark that is on the rear timing belt cover. There is the 0 | T reference that the | is the actual mark, but on a Digi if you look at the back there is still the dimple that
aligns with the Valve cover.
I set the Dizz so that the rotor is in the middle of the hash that is stamped on the side frame of the dizz. I don't try to rotate the Dizz to the pulley marks…ever.
Now if your dizz is pointing to a cylinder that is you have it so in effect you could be a few degrees on or off the mark.
The dizz when aligned is at 12-1:30 usually and that is plug 1. Then in Clock wise or to the right in order from plug 1 is plug 3, then 4 (opposite to 1) then 2.
http://cabby-info.com/Files/SparkPlugs.pdf has pretty pictures of this.
I can't imagine a Dizz without a mark for 1 cylinder.
http://www.cabby-info.com/Files/AdjustingTheTiming.pdf
Now with all this said, I did get a set of plugs (bosch triple fingered plats) that had a bad plug in it, and the second set I got had 2 bad plugs in the box. You might want to swap the plugs to make sure you haven't got a issue, as well as you removed the tip on the end (depends on which type of wire set you have) so the wire clicks firmly in place. At the time I was trying to diagnose a bad running car, I also had a bad plug wire on it. So trying to find a bad wire, I got a bad set of plugs, followed by another bad set of plugs that were worse, all to find out that my Original Plugs were good, and I had a bad HV wire…. (I was glad I had 2 cabbies to play with)….
On a digifant car, or CIS-e you can set the timing using a DVOM, on the bottom link I posted is a write up at the bottom that tells you how to do it.
It by ways and means also tests your Hall Effect sender…
I have had ICM's flake out after my Dizz broke the Hall Sender bracket and it shorted out…
Last edit: by Briano1234
