Handbrake light bulb
(In Topic #240826)
N 0177512 there are 2 one for the brake and one for the seatbelt.
The bulb holder is
171919244A
Sent from my AC2003 using Tapatalk
Do you have it plugged in correctly?
It shouldn't be working when you have your headlights on.
Are you sure the e-brake switch under the e-brake has the ground wire attached when depressed it is 0 ohms. Also check that f18 is good.
Here's the circuit.
