GTI grille and spot light question....
(In Topic #235775)
GTI grille and spot light question….During my refurb I have come to refit the spot lights into the front grille.I have noticed that looking at where the spotlight screws to the grille – the “spigot” you fix into is longer on passenger side than the drivers side !?!?!? I have two original Hella grilles and both are the same. This means that the passenger side spot light sits further forward then the drivers. I also have a rubber section that was fitted between the screw and the spigot. This makes the light stick out even further……..Any advice greatly received!!
Shorter drivers side spigot with rubber spacer
Recessed drivers side light
Longer passenger side spigot with spacer
Passenger light proud
