GTi fuel lines
(In Topic #211131)
Newbie, here with first help post, so go easy on me!
Got leaky fuel lines and looking best place for replacements - see photo.
Starting with rigid curved pipe into pump.
Believe is p/n 533201297 and vwheritage its £114!:
https://www.vwheritage.com/533201297-metal-fuel-pump-supply-hose-mk2-scirocco-mk1-cabriolet/
But think can get for £26 from:
http://www.allcarpartsfast.co.uk/vw-audi-seat-skoda/vw-audi-seat-skoda-533201297-pipe/
So anyone confirm if that's the correct part?
For hose between pump and accumulator believe its:
http://www.classic-vw.co.uk/mk1-golf-cabrio--scirocco-fuel-pipe-pump-to-accumulator-533201220-14343-p.asp
So last one is the hose from accumulator to feed pipe, but the one on classic-vw looks longer than one I removed, so this correct:
http://www.classic-vw.co.uk/mk1-golf-fuel-pipe-accumulator-to-main-supply-line-171201218c-7527-p.asp
Then finally the feed and return pipes - was going to make up myself with 8mm kunifer but looks kinda tricky where they pass up into engine bay.
Are the ones on classic-vw pre-bent or just a coil with fittings?
http://www.classic-vw.co.uk/mk1-golf-gti-rigid-fuel-line-kit-83-171201361b--171201217d-7678-p.asp
Or is just easier to spent money on flexis for £151 plus £7.50 shipping?
http://www.golfmk1.co.uk/Items.php?cat=SLAREA&group=UNDERSIDEFUEL
Sorry for lots of questions, so one last one - guessing worth becoming member for discounts, how much do members get for above sites?
John
plus link to feed/return lines above is for 83
Think correct for 84> is
http://www.classic-vw.co.uk/mk1-golf-gti-cabriolet-rigid-fuel-line-kit-84-533201361--533201217a-7686-p.asp
Otherwise someone does a kit of hydraulic/fuel type pipe with the correct fittings that's much easier to route from the tanks end to the engine end
Was sort of guessing would be tricky bending own pipes and trying install on stands - really need ramp and the clearance to manoeuvre up into engine bay.
So looks like the braided flexi lines at near £160 best option
Anyone know the member discounts to CQ and classic-vw?
Ref 1985 GTi cabby.
Plan to order all fuel lines/hoses from CQ so over £200 worth in basket so far, so bit of discount would be nice - if there a code for paid members?
Just still not sure about the hose from accumulator to feed pipe, still can't find the correct one as one on CQ says
Hatch and cab to '84
vw heritage also states
Golf Cabriolet 79-84 up to Chassis 15-E-011-290
So anyone confirm if correct if p/n is 171201218C?
John
Also worth noting, Rich advised you don't need the short hose from accumulator as the long feed braided hose connects directly to the accumulator so this offsets the cost of the long hoses by £34.50!
Wiring jedi
Www.jvsautoelectrical.co.uk
mcjjordan said
How did you get on with this as i need to do same with same year car?
yes recommend the braided hoses, easy to fit compared with 'rigid' pipes
hard to believe that was 4 years ago, was just before MOT as up again now
If you don't want the headache then you can look at the braided lines as the other members mention from experience.
what im looking for is a solution to replace the pipe & hose that go from swirl pot to the inlet of the fuel pump.
i think one of the pipes reduces in diameter and the metal pipe turns 180 degrees , ive seen on heritage they do them but works out like £100 just for them!
anyone shed any light on diameters so maybe i can make something up for a fraction on the price
Wiring jedi
Referring back to my photo above, I remember that 180 degree metal pipe on mine had a small pin hole (had been rubbing) so was dripping fuel and was struggling to make a piece similar so ended up cleaning up pipe (showed was solid bar small hole) and dropped small bit of solder to seal the small hole. Pipe is low pressure side of main pump and solder still holding strong now. Then hose either side of this pipe was just replaced with new standard rubber fuel hose and clips. Then short hose from outlet of pump to accumulater I got from CrazyQuiffs for around £20, then outlet from accumulater was new long braided hose from CQ which replaced existing short braided hose and corroded metal pipe.mcjjordan said
mines leaking like mad seems to have been bodged badly over the years with random hoses.
Not sure on diameters, recall 8mm but not 100% sure.
I spent all summer and about £2K changing my fuel tank, refurbing the rear axle, converting to discs, new master cylinder and servo, making many new brake lines all because I kept losing power and put it down to dirt in the fuel tank so replaced it along with pump accumulator etc.
Finally put it all back in place today and the hard feeder pipe has split / holed….. Grrrrrrrr
So I guess the poor running and not starting was down to low fuel pressure and not any of the other parts. (by the way I uncovered a load of rot and needed new chassis leg, inner and outer sill) - DID I SAY ITS TAKEN ALL SUMMMER……
Think I shall buy some new copper line and stitch in the straight length along the one side for now until I can afford the flexi line kit……
good thread and help me make my mind at to do a good bodge/repair for now.
