GTi cabby - how to best support/clip braided fuel hoses?
(In Topic #211497)
I bought a nice set of braided fuel hoses from CQ and fitted them few weeks back and just temporarily clipped them in using the same rubber supports and metal clips on underside of car. Now these supports are intended for the original rigid 8mm steel fuel lines so not really ideal for the larger OD braided hoses.
Doing final prep for first MOT in over 11 years so whats the best way to clip these?
Use P-clips? If yes, ok to just attach with self tappers?
Also any rules for MOT about gaps between clips for such hoses etc?
Found P-clips on ebay, so thinking something like these:
http://www.ebay.co.uk/itm/Rubber-Lined-P-Clips-Wiring-Hose-Clamp-Pipe-Cable-P-Clip-Metal-Zinc-Plated/262776387857?_trksid=p2045573.c100505.m3226&_trkparms=aid%3D555014%26algo%3DPL.DEFAULT%26ao%3D1%26asc%3D43782%26meid%3D46c1bbf5082f4e64ba0e0f11c000c3fc%26pid%3D100505%26rk%3D1%26rkt%3D1%26
Also the 2 spring type clips above the steering rack not working too well either - would be difficult to add P-clips due to access, so any suggestions?
John
Have used originals but don't seem as secure as original pipes so was thinking might be MOT fail esp here in NI as MOT centres are run by DVTA and inspectors latch onto anything non standard.
Was thinking maybe decent cable ties around each for extra security might do.
with the rubber around the hoses, it just looked bit bulky for the OE clips, but maybe I'm just fussing bout nothing!
agree rubber grommets off will reduce the bulk and clips should be more secure
thanks to all again
John
the new lines have the over-braid so you probably dont need the oem rubber, what I would suggest is get a thin strip of rubber or thick tape of some kind just to stop the lines and clips chafing together
Ian, on CQ page http://www.golfmk1.co.uk/Items.php?cat=SLAREA&group=UNDERSIDEFUEL, scroll done to FLCAB for both pressure/return lines - they were correct for my car - can also scrap the small exising braided hose from accumulator to pressure line as CQ hose is longer and joins directly to accumulator
Sent from my SM-G930F using Tapatalk
