Grille
(In Topic #208833)
Red trim
This could be a very silly Q soo sorry in advance..the red trim for the front grille..is it held on with anything ??as,if I just clip it on it doesn't feel the most secure and doesn't hold in place too well.. thanks for any help/direction with this
I personally would clean the plastic underneath on the grille, then use a clear or black bead of silicone RTV on the inside of the trim, place it on the car secure it with tape for 24 hours and it won't come off.
Here is a rear badge that held on after collision. Yes Black RTV.
Ouch!
I think
Gooner615
is referring to a GTI front grill.
That red beading can get hard/brittle over time and become lose and even fall off.
Not sure but you maybe able to get a new replacement one. So I'd try www.werk34.de as they do a lot of trim parts.
People do glue them back but it depends a lot on the condition of it as to how successful it is.
Some I've seen have just left it off and painted the red on by hand!
I think
It's not cheap as you would imagine but maybe other companies do it. Although these guys do good stuff I've found.
https://www.werk34.de/product_info.php/info/p10165_Trim-set-for-grille-4-piece--Golf-Mk1--Red.html
As long as the red trim still has the little lugs (see picture) that bend against the plastic part of the grille you should be fine. They usually get bent out of shape when being removed, shouldn't need more than your fingers to press them against the grille to hold tight.
If your trim is a bit 'wonky' you can get an Allen key (7mm I think..) lie it down in the reverse side of the trim and tap it gently to even out any bumps.
Paint it Mars Red 1.
Alternatively go ant buy some new, but not as satisfying.
Last edit: by RichardHall
Cheers guys,it's a brand new grill with brand new trim it just doesn't seem to fit that secure and wondered if there were clips that I am meant to use??
As Richard Hall said and shown in photo, there's tabs which you fold round the back of the grill line you are attaching to. They won't fold all the way round but enough to hold them on.
