Golf Mk1 stationair RPM
(In Topic #224645)
Motor works perfect in a high RPM……
But in stationair RPM …. he stops working… ( also without air filter)
It's a
carburettor
1B3Ignition is oke…….
I cleaned the two nozzels on top of the
carburettor
I orderd a new fuel filter
I can't find the solution…..I orderd a new fuel filter
Someone a hint
If mechanical fuel pump, does it run off the camshaft? Worn mechanical fuel pump may also cause issues as the diaphragm inside wears out.
You can test by removing the fuel pump outlet and someone cranking the engine to see if you are getting adequate fuel coming out in a container.
Sounds daft, but have you adjusted the idle speed on the carb? If so, then have you also chcked the mixture, its possible its too lean (or rich) at idle but at full throttle/high rpm its no longer an issue because the main jet starts working.
