Golf mk1 agu turbo oil pressure switches
(In Topic #216697)
Thanks in advance
the 0.3 bar switch wire should be yellow, the high should be blue/black, follow your conversion loom back till you find it in your harness. you'll probably find it behind the fusebox or tucked into the harness in the bay somewhere, depending on who made the loom for you
Thanks in advance
Many thanks in advance
the 1.8 bar switch blue/black wire goes to D/1, then A/4 in the clock loom, back to pin 9 on the clocks
Thanks for your help
