Glove box lift spring!
(In Topic #224517)
Reattaching spring
Any body know how to reattach the glove box lift spring?
Thanks in advance
R8J VW🥇
Don't suppose you know how to change the lock barrel on the glove box??
R8J VW🥇
to remove the barrel in the glovebox, put the key in the barrel, lift the glovebox lid, remove the c shaped plastic clip and push the barrel from the back to release it.
once removed you can swap for the one you have already or simply swap the tumbler plates to fit the same key as your ignition key
let me me know if you need anything else 👌🏻
Thanks for all the help.
R8J VW🥇
