Gearbox Flange Seal
(In Topic #228527)
Did I really do this???
Knocked the cv off with a hammer, rebuilt and oiled and replaced with new washers grease and circlips. All is well so I thought.
Then looked under the car and there is a pool of oil. ON closer inspection coming from the offside gearbox flange seal and the seal looks as if it has come out. Could tapping the outer opposite CV on have pushed this out?
And for replacement is it possible to tap it back in (first attempts say no) or do i have to take off the offside driveshaft and then get a flange puller in order to replace and re-seat it?
Any tips of tricks would be very helpful here, including where to get a flange puller if needed!
You don't need a puller to get it off, in fact the big spring will fling it off and nearly kill you. The hassle is getting it back on and re fitting the circip.
For all things VW MK1 GB see 020 Flange
