Gear Selector Lever - 4 speed
(In Topic #208810)
Can I get one of these new, I can't find any doing a search of the usual places, has anyone got a spare in good condition or can splines be re-made?
EDIT
If the shift rod is the same on a 4 speed and a 5 speed then I may be able to modify a 5 speed selector lever to fit
Last edit: by Blah blah
i have one but they don't have splines
That is the wiper arm is plain, and the shaft is splined.
What you need to do is to Brush the splines on the shaft free of metal shavings or corrosion.
Polish the inside of the link.
Where the link uses the "Pinch" to tighten it, you may want to file the slotted opening a little to get more bite.
Go back to using a new grade 8 or 10 bolt with a cupped washer Belleville Washer, then tighten to the correct torque. It could be that your bolt is worn on the threads and not holding torque sufficiently.
