Gas bonnet struts - fitting help
(In Topic #206760)
bought a set of these from eBay only £20 but come with no fitting instructions - anyone got pictures showing theirs fitted as it appears it needs holes drilled into the body and want to make sure I'm doing it right first! or a step by step guide if anyone has one?
thanks
thanks
Website Manager
The thought of drilling the wing and inner wing always filled me with dread !!
I prefer to modify the strut so that it fits between the bonnet bolt and a wing bolt.
I have found that you can unscrew the end off the strut ( a little heat might be required) and then shorten it and cut some more thread on, so that it all lines up with a wing bolt hole. I also prefer to use the fixing where it is bolted from under the wing, this requires the removal of the plastic arch liner if you have one.
Strut fitted:
Close up of shortened end:
Close of wing mounting:
Strut fitted:
Hey, not sure if you decided on your approach for this? I opted for the drilling wing method (!) wasn't easy as you have to take off inner arch covers and a lot of my screws were worn making it take ten times long!
1990 - Cabriolet GTI 1.8 (DX)
Er, my "pennyworth" (if you don't mind ?) why not put the "other end" on to the "other" bonnet hinge bolt (greater leverage, the strut could work better ?)
Have been on holiday so haven't given it a go yet
Will try to do it without drilling
Does anyone have the modified body/shaft length on these modded struts? I am looking to do this on my MK1 Rocco, thanks!
Sam
Sam
