Fuse replacement can't find online ?
(In Topic #217129)
Trying to rule out some electrical issues and would like to replace these
Any idea we're I will be able to get some online ?
Loads!
As Roach says, loads about as they are fitted to loads of cars.
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.X53+relay.TRS0&_nkw=53+relay&_sacat=0
Or go to a scrap yard and find any VAG car as I expect they are still used in today's car?
Was not sure if they were specific or not.
Thanks for coming back to me ill get a couple ordered now.
mark1gls said
Looking at the relay in your pictures it looks as if you have had water coming in the car in dripping on your fuse box as the legs of the relay look a little rusty?
I think unfortunately you are correct. The car was sat outside for 4 ish years prior to my ownership. Luckily it didn't go rusty but it did leak water in on to the fusebox..
I am battling with fuel pump issues at the moment and have replaced the fuel pump relay which had the same corrosion.
Will try and take some time and go through everything and clean it all up as best as possible this week and then hopefully it should start.
The other issue is around the windshield if there is Rust around it.
The Radio aerial if the co-ax doesn't have a drip stop loop then water can run in from there as well.
For Future reference.
Here is what a Fuse box look like internally.
NSFW "lol"
Did you notice that there was corrosion starting on f1 and f2 locations….?
Here are a Few fixes that I have come up with for debris issues with the drain tray drains.
Clean then and route all hoses and such out of them.
A good rain tray scuttle cover.
http://volkswagenownersclub.com/vw/showthread.php/108841-Why-is-it-raining-on-my-feet-I-just-changed-the-antenna
http://volkswagenownersclub.com/vw/showthread.php/32217-How-to-make-a-Hood-Debris-Guard
You can find OEM ones older yard or breaker rabbits.
Briano1234 said
Plugged Rain Drains on the Scuttle, cause water to back up in the tray and find any weak area as in Grommets or seals that pass-through.
NSFW "lol"
Thanks for coming back to me with that.
Ill check the f1 and f2 locations when i get chance this week
Im sure my scuttle isnt rusty but i will check to see what drain plugs are their if any
Thanks again for all your help
