Fuel Tank refurb parts
(In Topic #209684)
At the part in my build where the tank etc is almost going back in. Not sure what the correct name for it is but want to get some new tape/foam padding for the tank and tank straps? Any guidance on stuff anyone has used would be great.
Also the plastics which clip around the edge of the tank i don't seem to be able to find, think they're discontinued?
After taking the fuel level sender out of the tank the metal bar to the float is badly corroded. Planning on making a replacement but not sure what material would be best?
Any tips appreciated. Cheers
Just clean the float bar up with sandy paper or steel wool.
For padding the straps, I would use a product that you can get at a HOME Improvement Store. It is Foil Backed Self Sticky roofer tape, it is about 6 inches wide.
It is water proof and in strips on the top will deaden noise. You can pad the straps or the tank where the straps go.
It cuts in strips and sticks well.
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
Have a look on ebay for some 6mm self adhesive closed cell foam. Used alot for vans to deaden the sound in the back.
I've got a similar thing with my tank sender unit, it's a bit corroded too, but after having a quick look around I can only find GTI style lifter pump / sender unit combo's and they're ridiculous money used. I'd use a bit of aluminium wire if you can find it for the float wire
I have the plastics on my tnak and can take some dims and pics if it'd help? Make something of a similar size from a block of HDPE if you can find some or use some blue water pipe and split it and clip it on.
Ian
Ian
nope
That's a relief, had me panicking then!
Lift pump/sender is cabby only. Tin tops had different fuel system arrangement at the tank
Don't know if this will help, obviously pushing their product but still an interesting read. Perhaps your a bit further on!
How Do I Repair My Fuel Tank? - Frost Auto Restoration Techniques
