Fuel starvation only when moving
My Mk 1 will tick over all day but loses fuel when moving
Keith Usher said
which new pump did he fit, some of the new stuff is total garbage.
He initially bought a cheaper one and it made no difference so he bought an expensive one (but can't remember the make). Still the same problem.
i dont know what to do next now if i am honest?
http://www.ebay.co.uk/gds/How-an-Ignition-Control-Module-Works-/10000000178532970/g.htmllukecab said
hi all thanks for the replys ,do we know what the ignition module acctually does?.
your actual coil could also be going bad when hot.
It seems the car is ok now with the thermostat removed? is the water temp reading lower than normal now under normal driving conditions?
Last edit: by Keith Usher
The temp is reading at about 1/4 on the guage
Am hoping we found the culprit….this was the pipe that goes from the petrol cap to the tank. I think bits were falling off and getting into the fuel. Replaced with a new one……..everything crossed!
With the filler that bad and it stalling so readily it must be full of rust, muck and water?
Simply changing the filler won't solve your problems until the tank and lines are cleaned out. There was an article on here about syphoning the fuel and muck out saving having remove the tank (and exhaust/brakes/shocks/axle shearing lots of bolts and making your life a misery)
If your temp only goes to 1/4 , now the thermo is always open your engine is running to cold all the time.
You should have a petrol filter on the fuel line where it enters the engine bay, what condition does that look to be in? they are easy and cheap to change for a bigger one.
http://www.ebay.co.uk/itm/10-x-Universal-Petrol-Inline-Fuel-Filter-Large-Car-Part-Fit-6mm-8mm-Pipes-/152552510806?hash=item2384d69556:g:FqIAAOSwYvFZHUG-
You can chop out a section of the tintop filler neck and reweld the end back on to get the right angle, I was told you could bend it to fit but this does not work.
My rusty cabriolet filler neck next to a new tin top one.
Amount that needs cutting out.
All painted and ready to go on.
Buy a new rubber hose which goes between filler neck and tank and 2 new jubilee clips.
You will need to clean out what ever else has fell into your fuel tank and replace the fuel filters a couple of times to make sure all the bit's are out.
I'm surprised the rusty filler neck was not spotted earlier as that would be the 1st place I would look before looking inside the fuel tank…
Treat the new filler neck to lots of stone chip paint and protection, it's also worth cleaning around it twice a year to get all the mud out which sits ontop of the filler neck if you do use the car all year around and it gets wet and muddy.
Put your thermostat back in if still driving with out it, the car needs it there to regulate the coolant temp as it should read 1/2 on the gauge.
Last edit: by mark1gls
Early-1800 said
But you said you'd checked inside the tank?
I know it's hard to believe but the tank really was clear - I don't understand it either.
I guess we're not all that clever though eh?
We've got it sorted now thanks, the new one is on and seems to be doing the trick (fingers crossed). And yes the thermostat is back on as it made no difference.
Thanks for the advice.
mark1gls said
Glad it's all sorted and back on the road. If you ever need any help /advice we are always here to help.
Thank you it's much appreciated
