Fuel pump relay been bypassed?
(In Topic #204065)
How do I find out if the fuel relay has been bypassed? And if it has, how do I correct it? There are relays hanging by the fuse box with wires attached and all sorts. Causing me a right headache.
It's an 1989 cabriolet gti. It's as standard as far as I'm aware.
chase down the source of the whining, if you pull the relay it should kill both the fuel pumps and stop the car. if it doesnt then you have your main pump on an ignition feed or there is some kind of short between an ignition and pump feed or something.
chase all the relays that arte hanging about the place, chances are its an alarm system and if tapped into the fuel loom this could be why it doesnt kill the pump when running, but it does when you pull the relay before you start the car
This pressurizes the lines to assist and end vapor lock or hot start issues.
Now that you say it is whinning, that is because the main pump is over working to get fuel to the engine.
This can be caused by a bad filter.
Or anything from the lifter (in-tank) pump, to the main pump.
On the CIS this can be caused by the Accumulator or sump as well.
A bad ground can also be a issue some times as well.
The in-tank or (lifter) pump can fail because of rust particle in the tank. The Pump has been run continuously on less than half a tank as you only put a couple of bucks of fuel in it. The lifter pump uses the fuel surrounding it as a coolant and lubricant, so reduced fuel causes it to over heat and start failing.
The Lifter pump is also connected to the sending unit feed thru by a rubber hose that can hole (split) and or separate there by reducing the fuel to the main.
Removing the Fuel Pump Relay, removes power to both pumps, so nothing will work. (don't do that!).
If the main pump over works too much it will take a dump and you will have to replace it and still resolve the major cause of it's demise.
The whining noise isn't bothering me so much, it's the constant turning and turning before the engine fires up, and it is very slow and stuterry when it does fire up. I had presumed this was all linked but not sure. Any ideas?
Do you think it's worth me just removing the alarm and the 1000's of wires attached to it?!
the main pump must be powered from something else for sure, as there is no way a kjet car can run without this.
if it has an alarm as I say that would be my first thought, if the wiring to it is poor then I would certainly consider stripping it out anyway.
Adammmm said
Ok nice one cheers. I've had enough messing about for today, so back on it tomorrow. Why is nothing ever simple!
Ignoring a Whining pump, isn't going to resolve the issue.
Getting the correct fuel pump relay will. If the pumps run for more than four seconds on key on run position, then that is the relay.
Whining pumps isn't the relay usually and ignoring the issue is going to be more costly to repair when it stops altogether.
I will get the car jacked up tomorrow and find out exactly what is whining.
This whole issue is driving me mad.
