Fuel pump problem GTi
(In Topic #217445)
Lift pump runs, pressure pump doesn't
As soon as you wind over, the relay is waiting for a signal from the coil, check you have a spark at the plugs first. If you do, then check the Low voltage wire to the coil has the wire that goes to the relay connected
