fuel pump operation
(In Topic #242660)
good evening.
Should the fuel pump start running when I turn on the ignition. Mine seems to be dead when I turn the ignition on, despite the wiring having been checked. I have just replaced the tank, so the system is effectively dry at present.
1800 gti tin top 1985 k-jetronic
The fuel pumps prime for 4 seconds at key in and turned to the Run position.
There are known fuel pump relays that have wonky innards.
More on this at www.cabby-info.com
https://www.cabby-info.com/files/electrical/Relays_Kjetronic.pdf
It depends on what fuel pump relay is fitted, mine has never primed the system when switching on the ignition before starting the car, (I think mines a No 62 relay) I did fit an aftermarket relay when mine failed and that relay did prime the system then I found a genuine VW relay online and fitted that one so now back to no priming the pump before starting.
You could remove the fuel pump relay and the relay just below it, turn the other relay around till it fits where the fuel pump relay should go, then when you switch on the ignition the fuel pump should start to run even if the car is not started so you can test the system.
Ah, you have answered my next question. How to run the fuel pump without the engine running.. As the system is bone dry I need to get some fuel in the pipes and filter before trying to start the engine
A great help
P.S I'll keep the fire extinguisher handy
A great help
