fuel problem
(In Topic #243170)
1983 1800 gti DX engine. no fuel from injector
However I have taken No 1 injector out and there is no fuel coming out of the injector. Like wise if I take the injector off and put the pipe in a jar, I get nothing from the pipe which is clear. All done with the starter motor running of course. I shall have to get another injector off I guess to check them all eventually. I was trying to avoid pulling the injectors as they are a real pain to get out, even with a tool I have made for the job. Should I be looking at problems with the fuel distributor or something else?
Lifting the round plate in the metering head (use a magnet) should send petrol to the injectors
best to remove lines to the injectors or even better the injectors if doing tis for any length of time or you will fill the cylinder bores with petrol
a) it would be an easy fix and
b) the vehicle was sitting outside in a field for 7 years before I bought it as a project so anything could be stuck.
I'll certainly have a look at that first thanks.
However with a magnet on the centre bolt it moves up and down freely and seems to be concentric with the venturi, so I'm hesitant to fiddle with it. I might try a gentle vacuuming of the venturi tho'
Last edit: by golfy1
This is a contradiction, but as a system it's both very simple / robust, while at the same time aspects of it can be complicated / easily damaged.
Break something and it can be very expensive / time consuming to find and replace (if at all).
Quite a few old school sites scattered about when you search and well worth a read first.
Just a random one to start you - https://tasteslikepetrol.net/2020/02/bosch-k-jetronic-basics/
golfy1 said
It's pretty manky in there
Post some pics, how do you mean manky? has some wildlife been in residence? Has it drawn stuff into the inlet manifold/engine?
Is fuel getting to the injectors by running the pump and lifting the metering flap?
![WP_20240617_10_29_52_Pro[1].jpg WP_20240617_10_29_52_Pro[1].jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1718638010/uploads/attachments/667055b9e32e2.jpg)
if you run the pump and lift the flap do the injectors work?
As usually I see them bright and shiny.
I'll try leaving out the fuel pump relay and just join the two large blades in the relay socket. Could be the problem with the ignition switch has come back. I'll do some more fettling tomorrow
