fuel metering head CO mixture screw
(In Topic #211626)
IVe daffodil my fueling and mixture up pleeeease help
Last edit: by Gooner615
If its the idle air screw in the back of the throttle body, make sure the O ring on it isn't flattened out.
Otherwise you can suck in too much air and not set the RPM correctly.
But that's worth looking at also.
These often shrink or get a flat spot so send the car running funny.
Before setting the Mixture you need to make sure the car is fully serviced with a clean air filter and timing spot on then get the mixture adjusted as that's the last thing to mess with.
1.5 to 2 % is what you are looking for.
