Fuel lines I think help
(In Topic #209509)
Does your friend not know what a fuel gauge look like?
How old is your main fuel filter in the engine bay?
Injections cars reallly don't like being run out of fuel and it's best to keep them no lower than 1/4 tank as the lift pump is cooled by the petrol.
Lift pump can be got at from a hole just below the rear seat, if you need help or advice on getting it out let me know.
Filter lives here.
There so 2 types depending on age of car, cars from1985ish have a bigger fuel filter like mine.
It's also worth fitting some new copper washers, 1 end is the same size as sump plug washer and the other end is slightly smaller but sometimes you get 1 with the filter then match up a new washer in a shop.
Last edit: by mark1gls
