Front suspension load washer
(In Topic #222409)
I didn’t touch the O/S so I’m guessing the o/s DOES have the load washer.
KP
Position 1 on attached diagram.
The bump stop wouldn't go any further down the shaft and sits on the collar at the thicker part. washer would just sit on top of that right?
Mk1 Golf Suspension Top mount 171412329A MEYLE Jetta Caddy Scirocco.pdf
KPCabrio said
Nope
yep!
it stops the strut from pushing up through the center bearing. The washer on top holds it tight to the bearing so that there is no up or down play in the Strut Cartridge shaft to the bearing, and allows it to easily pivot inside of the bearing….
On some of the mounts that I have gotten I have had to file the inner bearing a bit more flush as there was too much play between the shaft and the bearing to the washer on top under load of the suspension. Leads to pre-mature failure of the mount and a small hammering noise on a bump.
cedar said
I always thought that washer spread the load of the strut on the spring cap. The shoulder on the strut isn't all that wide and without the washer it could push through the cap.
Briano1234 said
The washer becomes part of a sandwich.
Thanks Guys.
looks like I'm taking it all apart again.
We once drove a Mk2 around for a week or so without that washer because I lost it when we dismantled the strut, it was okay.
