Flywheel timing marks - 1.8 DX
(In Topic #223632)
Quick Q - I only seem to have one mark on my flywheel, from other pics I've seen online this looks like the proper 6 deg BTDC timing mark and not the TDC mark (which is apparently just a dot). Is this correct? Marked in white paint below…
Ta!
J
Regional Host NE
ti figure things out in what direction you need
to go BTDC OR TDCC
So is the consensus that if there is only one mark, it's probably not the timing mark? It's odd because it's the right shape for the timing mark, but I'd expect to see a TDC mark.
Engine is at TDC so I'll put the gbox on and see what the pointer points to!
It was way funner on a Diesel…If it wasn't at 0…
Oh and the cam dot on the back side when even with the Valve cover tin, tells you that your Cam lobes for number 1 cylinder are straight up.
Here's another.
Briano1234 said
good eyes
Thanks Briano
I can confirm that after managing to get the gearbox on the block all by my socially distancing self, that the mark I have is not tdc, so I think Steve has called it correctly!
Since the last few weeks, I keep hearing Eric Carmen's "All By Myself" shoot there I go again, I suspect that this should be moved to the "Tune of the Day" thread.
yep that could be misconstrued, but I know what you meant. I'm well past millenial!
I'm pretty sure I only had assitance in days gone by because of the free beers and fags (sorry, smokes to you over the pond).
Steve1973 said
If it is indeed your TDC mark I would touch it with a drill to make it a bit clearer.
If I can get to it now I've got the box on! I'm sure I can get a dremel in there….
