Flashing temperature led.
(In Topic #216034)
Does anyone know what value resistor I'll need when bridging the coolant level wires so I can stop the red led flashing on the dash?
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Ok, from a interweb search….
The resistance must be between 31K Ohm and 65K Ohm with correct COOLANT … 50/50 blend of
a/f to H20.
From this thread.
vanagonauts.com - This website is for sale! - vanagonauts Resources and Information.
a/f to H20.
From this thread.
short the pins, thats all you need to do ce1 or ce2 to disable the light/test the system
technically on ce1 all you do is remove the 42/43 relay, but shorting the pins will do the same job.
for ce2 fusebox poverty spec mk2 without a header tank come with the level sender pins on the fusebox shorted together from the factory (no control relay on these, then logic is built into the clocks)
Bloody flashing temperature light has come back I've checked the short and it's good, introduced a new just to be safe but still it flashes?
Is it anything to do with the outside temperature being low?
EDIT … it's stopped now!!!
Last edit: by Pete M
if its still flashing even with the loop, its probably dash sensor issue or maybe a wiring fault. unplug the sensor, see if it stops
