Fitting Audi TT heated seats
(In Topic #234385)
Hi, i’m planning to do this and just wondering about a dash switch. For simplicity i plan to have both seats wired to one switch. But ive noticed the mk1 dash switches are very expensive. Are later switches such as a Mk3 compatible i.e. the right size to fit a mk1 dash?
‘81 Golf GTi Mk1 TSR1600 tintop
'90s Chesil Speedster on '70 VW Beetle Chassis
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Trying to work out why this costs so much? Does it have a built in relay to handle the amperage?
https://www.heritagepartscentre.com/uk/357963563-heated-seat-switch.html
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
If you look at the Bentley, the heated seat in a scirroco or a cabriolet don't have a relay, the seat switch controls the amount of current that the seats use, and I wouldn't use a single switch but a dual as the doubled load on a single seat would either melt wires or cause a fuse to blow.
Ah interesting. Now im not sure if i need the “control unit” - whatever that is…?
I see your point about having one switch per seat. Do i need the proper expensive ones from Heritage?
And secondly where to place them. With my single switch idea i was going to use the one blank switch on the dash below the hazard light switch etc. Where to mount the two seat switches…? (I have an ‘80 tintop gti btw)
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Been giving this some more thought.
Think i could maybe mount both switches inside the ashtray - seen it done for other control systems such as air suspension.
Wondering if the best bet is to buy two Audi TT heated seat switches (the round ones) and then send power to them.
Thoughts?
Thoughts?
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Bit more on this one. So ive found out from the TT forum that the seat control switch has the relay (solid state) as part of it (see diagram). So I have the seats and can get the control switches, and from my basic understaning of wiring diagrams , i think that should work. What do you think [mention]Briano1234 [/mention] ?
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
How did you get on with the install and wiring of the seats. Considering doing this on my tin top
Ah still on the To Do list!
Got two swtiches from a scrap TT as these contain the relay AFAIK. Ran a decent wire from the battery and was going to add a chunky inline fuse (20amp?), then create a simple harness to the two seats. The main thing i was mulling over was where to mount the two TT switches as i want them out of sight as they dont match the interior. Was thinking of tucking them under the recess beneath the ashtray holder and above the central console.
(What i was going to do first before all that was just run a wire direct from an old car battery in the garage to check the seats actually heat up first!)
So in theory, i have the kit, have a plan and just need to do it!
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
