Fitted Accuspark and car wont start !
(In Topic #209871)
-First i fitted new 3.0 Ohm standard coil to replace old 1.5 Ohm ballast coil. I didnt use resistor wire, instead I made all new wire from the back of the fusebox. First I fitted it to G01 (new style fusebox) - i measured that its ignition switched +12V. After that i fitted it into D15 witch is lead for that resistor wire, that is now plugged and hanging in the bay.
-Here is all wires that goes into coil right now :
+ 15 side :
1. Brown wire . I suppose this is 12V from starter while turning key.
2. Red wire. This is ignition switched 12V i pulld from fusebox.
3. Red wire. This is from Accuspark red wire.
4. Black wire. My wire for volt gauge.
- 1 side :
1. Green wire. Goes to Accuspark's black wire.
2. Red/black wire. This is for tacho ?
Double checked everything couple of times and there shoudnt be problems with wires. Right ?
-Before I removed dizzy from engine I scraped small marks so after reinstall dizzy should be aligned or atleast close enought to start.
-After I fitted Accuspark unit and magnet trigger ring I noticed that I have to sand rotor abit so it sits in the groove. I measured that I didnt sand too much and rotor still should hit contacts on the cap.
-Also I ordered spare trigger ring and tried that one also without any luck.
When I first tried to start car, it turns but wont start. Tried second time right after and heard REALLY loud bang.
No smoke or anything and didnt see anything wrong.
Later same thing happened. First start, no luck. Second start right after, BANG.
After that second bang whenever i tried to start i only turned key once, even if i tryed to start it for long time i didnt get any loud sounds.
Sorry for long post, but Im totally lost what could be wrong. Only thing i can think of anymore is faulty coil or accuspark unit.
Im prob gonna try it with original ballast coil and with that resistor wire tomorrow..
Is it carb or injection?
The bang could be back fire through the carb, which could be timing out.
Also, are the plug leads definitely back on the dizzy in the right order? I've done that before when you're sure you've done it right and they're wrong order.
I reckon your timing is out.
I fitted an Accuspark kit to my 1978 Mk1 Scirocco, I used the original coil (ballast type).
Have a read of how I fitted mine, I did have to tweak the timing a little to get it to run.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrics_2%2Felectronic-ignition_16#post_1316554
edit… The link seems to go half way through the thread, scroll up and you can read how and to what I fitted mine, with lots of help from rubjonny I got there in the end.
And iv got the blade fuses.
Tomorrow ill tweak ignition timing and hope ill get it started!
Keep at it as it will be worth it in the end as not more buying condensers and points every years then adjusting points gap.
I got messed up when i re installed dizzy, timing was 180 degrees off. Got it all sorted and car running thanks !
