Feel like crying! - Alarm / Start issues
(In Topic #206452)
Literally cannot believe my luck, hoping to attend my 1st AGM this year after finally getting my car ready, all cleaned and set sitting nearly in the garage.
Have noticed some odd behaviour from my immobiliser (Toad AI606 & AS620) past week, light would normally go green after disarm then you'd hear fuel pump. However, it's now orange and a red flicker came on intermittently this week just gone.
This evening however, just after fitting a new air filter, I went to turn the car on to test all is well…. and it isn't! Alarm disables perfectly well, orange light on immobiliser indicator but no fuel pump noise what so ever, car does crank just fine & all electrics working (windows, roof, lights, indicators, alarm etc.. battery measures 12.6v when off too).
What on earth could I have possibly done wrong here?? Have I dislodged something when swapping out the air filter? Why is the immobiliser orange and no longer green when disarmed?
I'm at work tomorrow and Friday and not the handiest of people when it comes to fixing a car myself - feel pretty low that I might miss out on getting my car up there now.
Any suggestions hugely welcomed right now
1990 - Cabriolet GTI 1.8 (DX)
Are you 100% sure that there are no loose wires that have fallen down behind the battery or around the air filter, very easy to dislodge something when removing the air filter clips.
RichardHall said
I really don't have much idea but for what it's worth when my Mk1 had an akarm and immobiliser fitted there was a live feed taken off one of the spade terminals on the battery.
Hi Richard,
Appreciate you having a look at this for me - just been down to check. Cannot see anywhere anything loose, poorly connected or simply not connected at all with regards to wiring around the battery / air box.
If you can access all the connections and they are good, then the alarm is gone. These do have shelf life and depending on what the relays are switching, they can last the life of the car, or fail after a few months. Water ingress through the loom?, this can kill the best of alarm systems.
If it's the alarm, then depending how it was installed, it could take a day to 'rewire' cut looms.
Don't be tempted by any other means, you will regret it.
rubjonny said
check the red/black wires on the coil, and check fuel pump fuse #5. if 5 has blown, check the wiring to the WUR and AAV as they are fed from this, and if they are damaged a short here pops the fuse
Hi Johnny,
I checked position 5 last night and it looks fine. Could you expand on the WUR and AAV please? Not acronyms I'm familiar with in afraid
I also read another of your posts previously about the fuel pump relay switch and its numbering. I had a look for this last night and couldn't even find one !!
Popped down to the garage this evening (just) as have been working late, not what I wanted!! I was attempting to get the existing relay out of position 2 in order to try what you said previously! Damn thing would not come out for love nor money.
I pressed it back in as it had moved a little - for some reason before heading back upstairs I thought I'd try the car again, alarm fob press - key in ignition - hey presto, life in the pump again!!??
I've taken some photos of what I could, have no idea what is in relay socket 2? Nor any idea what this loose block is with the 3 wires going in.
Any thoughts now at all??!
the other relay is most likely related to your alarm, its not an oem VW one thats for sure
if your relay primes the pumps with ignition disconnect one of the wires to the main pump and see if you can hear the lifter pump prime. if it doesnt prime then try to swap the 17/18/100 relay to slot 2 then the pumps will always be on with the ignition so you can then check the lifter
Ultimately, I think it would be worth pulling all relays to check the tabs are all clean and not crusty - same for the connections on the back of the fuse board too.
Maybe the car has suffered a water leak in the past?
So despite breaking down en route to the AGM with the same fault, after a little wiggle of all relays, the car came back alive and we made it to Stratford.
Car safely tucked back in garage waiting on me to take off the knee bar to give better access to check all fuses / back of fuse panel / associated wires etc…
Will most likely come back to this thread in the near future, so a HUGE thanks for helping me make it to my first AGM. Saw some absolutely amazing cars and have new inspiration for my little car! Thanks again, much appreciated indeed !!
Join up 30 and 87 will over ride relay
If standard type relay not ford type
at a push a VW 53 relay also works, but pinsd 30 and 87 are too small to fit into the fuel pump socket sockets properly
