Failed MOT - Help please!
(In Topic #235426)
I have a 1989 Clipper that recent failed it's MOT and I was hoping for some advice on the failures and how to fix!
Failure 1 - Driver's seat fore and aft adjustment mechanism not functioning as intended. (6.2.5 (b) (i))
Any suggestions? Haven't taken a proper look yet, assuming the mechanism can't be too complicated…?
Failure 2 - Parking brake efficiency below requirements (1.4.2 (a) (i))
Hoping this can be fixed by simply adjusting? I assume the cable adjustment isn't too complicated? I read something about a hole with a wedge you can adjust with a screwdriver…?
Failure 3 - Nearside Brake pipe excessively corroded front to rear at rear (1.1.11 ©)
Main help I would like here is knowing which part to order. There seem to be lots of rear lines with different lengths. Are they side specific and how do you know what length you need?
Is this correct : https://www.classic-vw.co.uk/mk1-golf-rear-brake-line-body---rear-beam-175611775-scirocco-jetta-15355-p.asp
Any help much appreciated!
Cheers,
Russell
2 Assuming the rear brakes actually work as not failed on service test. The handbrake cables can be adjusted via nuts under the plastic hand brake lever cover. The rear self adjuster never self adjusts and can be manually adjusted by using a pointy screw driver to pull down the adjuster wedge via a bolt hole. This takes up the slack so less or no cable adjustment is needed.
3. Sounds like the metal front to rear pipe not the rubber flexi. Good luck with this one, to replace properly it will need feeding up the bulk head around the anti roll bar, steering rack etc. At the rear end the joints will prob be rusted blobs and you may end up having to replace the flexi and other solid line.
Basically debating leaving it off the road this year or wether I can DIY it and save money then retest. Bloody living costs 🤣
Unless you are a keen and vaguely competent DIYer the brakes could be a problem, access is bad at both ends, the car needs to be up on axle stands (ideally a lift) and new lines making/bending and installing with correct ends etc.
Part of the fun for me is MK1 problem solving and DIYing servcing and repairs that has meant I have a few tools (brake pipe flaring/bending etc) and experience now but until I did jobs for the first time I'd never done it before…..
If it's just the short bit you can buy ready made lines but you will need some proper brake line spanners so you don't round the connectors off, it may be best left to a garage if you don't know what your doing as it's should not take them anymore than an hour to replace the line and bleed the brakes.
https://www.classic-vw.co.uk/mk1-golf-rear-brake-line-wheel-cylinder---rear-beam-scirocco-jetta-14559-p.asp
Thanks for you help again.
