EngineTemperature warning light
(In Topic #241097)
This has started happening recently but only 1 out of 3 drive outs otherwise no light and runs good with fan kicking in when it should.
Temp sensor switch was renewed about 2 years ago.
Thanks👍
1990 Golf GTI cabrio 1.8i. DX Engine
The light flashes if there’s low coolant level so check the level before doing anything else.
The sensor for the flashing light is in the coolant expansion tank, remove the electrical connector and check it's not gone rusty inside the connector.
If it's ok remove the sensor from the expansion tank and clean up the 2 metal probes on the end as they can go crusty over time.
Go carefully removing and installing the sensor back in the expansion tank as it's a plastic screw thread in a plastic bottle, I did had to wrap a bit of PTFE on the threads to seal mine.
Cheers.
If the temp sender, level sender and relay are all good it is very likely that the guage has gone bad. There is a capacitor on that board that can fail with age and cause issues. Check everything else first as that isn't an easy job to replace (compared to the rest).
