Engine mount bush
Hi all, I have a 1991 Gti DX engine I wanted to know how easy it is to do an engine mount timing belt side, as mine has deteriorated. I have took the mount bolt out but there are 4 Allen key bolts holding the bush mount attached to the engine. Any advice is much appreciated.
Sent from my AC2003 using Tapatalk
BIG hint, on the 2 rear bolts on the mounting bracket.
replace them with hex headed bolts the same length and grade 8 0r better.  WAY easier to get in and out the next time.
Also whilst you are doing the timing belt you might as well do the water pump.
Is a lot of work
Timing belt and pulleys need to come off.
I think on mine I even had to remove the alternator.
Next is to get the bush out of the bracket.
Than new one to be pressed in bracket for which a hydraulic press is needed
Than re-assemble everything
Success
Mine was running a lot more silent with the new silent block
