Earthing points!!!
(In Topic #219453)
Electrical Gremlins
I'm having issues with the dash lights been incorrect and other bits and pieces. Does anyone have any pictures of the earthing points in the engine bay? Mk2 1.8 Cabriolet.
That one can cause some strange things to happen if it's missing….
battery earth -> hole in chassis leg -> gearbox
brown ring terminals in engine wiring loom -> side of head/block
brown ring terminal in ignition/ecu harness -> to battery
headlight loom thick brown wire -> battery earth -> white 4 way spade block behind fusebox
wire from rear of white 4 spade block above -> earth claw above fusebox. if 2 claws, wire between claws to link them
engine loom white fusebox plug brown wire with spade -> to white block above
dash loom brown wire with spade -> white block
rear wiring loom brown -> white block
any other random small brown spades -> to claw above fusebox
any loose ring terminals under dash at either corner -> stud on a pillar
rear lights, washer pump -> earth to shell either between the lamp units, or under boot carpet, or maybe behind the boot cards either side
tailgate wiring -> as above
