Does anyone know what this is please? Part number or name would be great
(In Topic #229691)
It’s either this
https://www.classic-vw.co.uk/vacuum-non-return-valve-171611933-mk1--2-golf-jetta-scirocco-caddy-20804-p.asp
Or this, depending which engine you have :-)
https://www.classic-vw.co.uk/vacuum-non-return-valve-k-jet-172611931c-171611931c-mk1--2-golf-jetta-scirocco-caddy-23141-p.asp
Looks like the 2nd one for gti
Great many thanks - i clumsily snapped one of the outputs with my arm
I've done 2 over the last 20 years….. the spare outlet/inlet with the green cap on it. This time I just taped up the hole.
I have now managed to secure the valve along with the attached pipe.
What is the best way to bend the pipe - its plastic (hard) and is stuck in a U form near the valve. I was thinking of applying some heat… I have tried hot water but not boiling and its not really worked. Any tips on getting the tube in the right shape, form?
Thanks!
Thanks!
If you can get a spring in it to retain the inner shape be careful as with out it you could collapse or kink the tubing. I have seen folks that break that pipe and then remove the check valve and use hose. So all is not lost if you do kink it.
Thanks!! That's a relief! As they do sell them without the shrink tube.
new non returns are available through mark carter, hugh coffey and ebay. if you need another temp fix , try large bore syringe(needle ) stick need into damaged pipe and glue in place ,you then have ready mage push tube point to push vacuum pipe.
On the drive
Myvalver 89 GTi Grey mk2 16v
