Dizzy cap 1800
(In Topic #212840)
what do I fit?
Why do you think you need to replace it, have you checked the inside terminals for corrosion (it can be cleaned off)
When I took it off the copper contacts were black, I cleaned them up and noticed that 2 of them have a bit of a grove in them, so hence why I thought rightly or wrongly change it? Interestingly when a mechanic was looking at it two weeks ago he said that the spark was not strong, maybe I have discovered the reason?
ians28 said
1983 - the only number I can find is 1235 522 056. the cap does not seem to sit right it wobbles around until clipped? I'm not sure it is the right one, however, it could be the original one I cant recall changing it.
Yes the corrosion of the contacts will limit spark but now they are cleaned it will be fine, you can take your time finding a new one. I have had better results with old OG bosch caps than with poor new replacements. Clean the tip of the rotor arm too.
