Distributor rotor
(In Topic #213261)
whats the difference between these two rotors ?
Both will work in a VW, later cars with fuel injection have a rev limiter in the fuel pump relay so use the bottom rotor arm and early car use the top rotor arm.
You can run without a rev limiter just don't go into the red on the rev counter but to be honest no real point getting that close to the red as the power drops off that high up the rev range.
Distributor rotor
