Cutting out on heavy breaking
(In Topic #221598)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1464255468.jpg)
![Tucker2024 in the usergroup ‘Local’ Tucker2024 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
So….
I have had a reoccurring issue of cutting out in my mk1 gti cabby
It cuts out if I leave it running for long periods of time not moving and if I am very heaving on the breaks I have just changed to many parts to mention now I’m looking at the fuse board
I have had a feel and the relay which I believe is the load reduction relay is getting really hot I took this out with the car running and it cut out straight away
What’s the chances this is my fault
If so most of the numbers have rubbed off it could anyone help me to buy the right one
Don't think it is that.
Bad Grounds, Vacuum leaks come to mind first.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2car.jpg)
![cbro7092 in the usergroup ‘Regular’ cbro7092 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Sent from my SM-G955U1 using Tapatalk
![](https://uploads.tapatalk-cdn.com/20190710/b1e076b4c25ab77a6182fe89faf50145.jpg)
Tucker2024 said
think this could be the problem
That would be one of the many ground issues I was thinking of.
