Courtesy light
(In Topic #242348)
Rewiring and replacing courtesy light
Apparently this vehicle was sitting outside in a field for seven years, so plenty of time for nest building and wire munching. I had mice nests in both the sills, fortunately the sills had to be replaced so the nest material was removed along with the old sills. Stored vehicles seem to be very prone to rodent damage so it pays to keep plenty of rat/mouse poison around and in vehicles. Alternately have your BANNED WORD cat's bed in the garage, cuts down on cat food as well.
Mk1 Golf GTI April 1983
I used 823-947-105/B/GEN from Heritage, which was supposed to fit. I suspect that 111-947-111/E / might have fitted exactly, but as the width isn't stated it would be pot luck.
Last edit: by golfy1
As the US westy (rabbits) used a square one in the middle of the headliner, whereas the Cabriolets (verts) had one at the front windscreen.
If yours was a front wind screen then you might want to look at:
https://www.vwvortex.com/threads/upgrade-stock-interior-dome-light-to-time-delay-mk3-dome-light.4906051/?id=4906051
