Coolant system went pop
(In Topic #202861)
1.) Is this a viable home repair for someone who has only replaced the headlights on their mk1 before and hasn't touched anything pipe related? what are the steps to do this?
2.) if 1 is viable, what parts would you recommend I purchase, given I don't know where the leak is, I'm guessing I might as well replace all the usual suspects so I'm not chasing the leak around
3.) Given I had to drive it home for about 15 minutes (with regular stops to let it cool down) what kind of damage could have occurred to the engine that I need to get checked
Thanks chaps
Richard
If it's just the broken sender that caused the leak, then that's all you need to replace so easy fix.
Which sender was it?
Mark at Classic-VW will help you out for parts
If you weren't driving the engine with temp gauge in the red and it boiling then hopefully there's no other damage. Worst case is you've don'e your head gasket but hopefully that wont happen
Fill the system back up and run the engine till you find the leak.
The hardest thing about changing the hoses is getting the old one off as they have a sprung clip which needs squeezing to remove, I use a pipe wrench or mole grips to undo mine and a little twist to get the old hose off. You may have jubilee clips fitted if the hoses have been changed before.
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14913
The last two I replaced I didn't know it until I saw steam and flowing fluids out of the water pump.
For weeks I had looked all over for my leak, and even with a UV light couldn't find it….
It appears that the leak was dribbling out hitting the back side of the pulley and scattering to the wind.
On my Olds I was 300 miles from home in a State Park for a wedding…. no tools.. I had to buy 30 dollars in tools, to replace a 20 dollar pump… In the dark, Pouring, Drenching Rain… After the Wedding and Prior to the Dinner…..
Now be sure that your new pump has a metal impeller.
Over hear we now have available Solid Aluminum Radiators Available. Not the Plastic/Aluminum ones….
When my Diesel had 20,009 miles on it, yep 9 miles out of warranty the Radiator ripped up the tanks both sides.
Fortunately for me my Radiator guy had a Solid Brass/Copper replacement for 30 dollars less than the dealer…
I never ever had any further Radiator issues with that.
http://www.ebay.com/itm/ALUMINUM-ALLOY-RADIATOR-VW-GOLF-RABBIT-SCIROCCO-GTI-MK1-MK2-8V-M-T-/290949383895
It isn't that much more than the Standard Radiator, and all metal…. (I HATE PLASTIC PARTS).
