Clutch cable pulled through
Hi guys. I was out yesterday catching the last of the dry weather in my cabby and pulled up to reverse into a parking spot.
All of a sudden there was a bang and the clutch pedal hit the floor.
First thoughts were a snapped cable or bulkhead had been pulled through which was unlikely as it had a repair plate fitted before i bought it.
Popped the bonnet and cable and bulkhead looked ok so checked the pedal end.
Aaaaarrrrgggghhhhh. The cable had literally ripped the surrounding metal open and pulled through also snapping the small rectangle eyelet on the inner cable.
I know the clutches are heavy on these cars but never thought it could make this much of a mess.
Have had to leave the car parked up in a car park overnight which i really wasnt happy about but will be going to get it towed back today.
I will post a picture later but was wondering if i am the only one this has happened to and if not how did the repair go? ( is there a repair panel for this end )
Thanks all
1990 Golf GTI cabrio 1.8i.  DX Engine
did the repair plate crack?  I have had 13 mk1's and all have had the cable pull through, last one I repaired I cut out a section of bulkhead and raintray from a breaker. as it had already had a bad repair. after welding in a new section of bulkhead I reinforced from the back so didn't need a plate in the bay can see the breaker was cracked around the hole
The bulkhead in the engine bay has already had a repair plate so that is o.k.
Is that a repair plate in the last picture that you have done sporttrucker?
VWs really bad UK design shows it's ugly head again….
If the stick on repair plate has also pulled through/cracked the bulk head then I'm sorry to say it's a bigger task to fix as you will need an even bigger repair plate made and the bulk head strengthen, at least inlet manifold removed and carpets etc if you get it welded in place or easier to bolt some thing in.
The other option is a later South African Mk1 golf clutch cable linkage kit, VW did make a different design for the later cars which was a bracket fitted to the bulk head and that is where the cable would pull from not the bulk head.
Only picture I can find and on google link as it's from Photobucket, (1982 mk2 build - Scirocco Register)
You can just about see the bracket which fixes to the bulkhead?
south africa mk1 golf clutch cable - Google Search
last pic is a bracket to strengthen the bulkhead
if the clutch carrier broke off the pedal assembly which happens,,,, then there is a fix.
Clutch cable big-time issues...Poor Otto...PICS! | VW Vortex - Volkswagen Forum
and
Clutch Cable Carrier Tube breaky.... | VW Vortex - Volkswagen Forum
Has the cheaper fix from your local hardware store.
http://www.golfmkv.com/forums/showpost.php?p=2944420&postcount=22985
