Clutch cable
(In Topic #207766)
Sent from my KYOCERA-C6745 using Tapatalk
It's mainly couch cable it keeps going in silly places makes clutch bit heavy. I have even changed cable for 45' angle one instead of straight which was fitted. Still no better
It mainly goes down side of brake marster cyn and dizzy cap I don't want put any tension on cable in case burns out clutch
clutch cable i ran mine round the front of the engine and used a mk2 cable bracket to keep it still:
others have cable tied the cable to the master cylinder to keep it still
I will get mk2 cable try that.
As its easy change clutch cable as have had the clip off the pedal loads time to remove pedal makes it easy
quite hard to find these days, you need the manually adjustible cable type ideally as the self-adjusting bracket is too big. but you can cable tie the clutch cable to it though, maybe this piccy will help show what I mean:
for the speedo cable you might get away with oiling it up, on my 1.6 it was jumpy becasue all the outer cover had cracked and dried it out. so what i did was clean up any loose ends of cable then gave it a couple sprays of oil where the cable was exposed to the elements. left it a bit then dried off all the excess oil and covered all the exposed areas with hevy duty duct tape. after a couple days the speedo was smooth as silk once again
