Clipper rear bumper iron
(In Topic #211720)
Rotten metalwork
The skin is held in place with wedges into clips in the skin.
Put a wanted post up in the wanted section and post in the car breaking section.
You may be able to buy them now but check they fit a cabriolet with the bigger bumper 1988 onwards.
The bumper skin is held on with wedges along the metal bar (you can see the black wedges in the 2nd picture)and I had a bead of masket along the top between the skin and metal bar which was a real pain to cut through, I used a long bladed craft knife to cut through the masket so I could pull the bumper skin off, I then removed the sticky masket from the bumper metal and did not use anything when putting it back together as you need to remove the bumper skin to get to the bolt to remove the bumper irons.
Not much metal left!
I took what I had left into a metal works and got these made.
http://www.ebay.co.uk/itm/MK1-GOLF-Bumper-Bracket-Front-Plastic-Bumper-171807113B-/391385887153
Found these in Germany which will fit, they also stock the other side, they don't seem to sell the bumper bar if you need that as well?
I got away with cleaning and painting mine.
https://www.werk34.de/product_info.php/info/p18814_bumper-bracket--rear-left--fit-for-Golf-I-Cabrio-1988-model.html
Last edit: by mark1gls
