carburetor help please
(In Topic #216933)
Membership Secretary
Hi all this is my 1st post here . I am looking for anybody who knows anything about carburetors and can strip down clean and rebuild one in the northwest area thanks
Thanks Rick
Membership secretary
What car you got and what carb is fitted, original Pierburg or a Webber?
It's a mk1 golf S1 all still original, solex 31 pict 5
Thanks Rick
The car is a 1980 mk1 golf S1 all original solex 31 pict 5 carb, the cars been stood in a dry garage for 25 years, the car starts and runs but won't run without the choke on, l believe it's the choke side in the carb and needs stripping and cleaning, there is a kit to referb it and was looking for somebody to do it or somewhere to take it for them to do thanks
Thanks Rick
If it only idles on the choke, try loosening the idle jet on the right side of the carb. Nothing will pour out, you can unscrew it and soak/blast clean it and put it back in. DId the trick on mine. The idle jet is the slotted hex screw in the middle, with a little ball inside.
Early 77 year model Golf. 4-Door
Thanks for that il try it later, do u no what the little grommet screw above the idle jet is for only l lost that screw lol thanks again
Thanks Rick
It's just a sealing plug. On small block engines I think there's also an additional jet behind it, but not on my 1.6. It's actually still available from vwclassicparts part nr 113 129 419
