CAR WONT START
(In Topic #203992)
![shaunyp in the usergroup ‘Paid Member’ shaunyp in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![shaunyp in the usergroup ‘Local’ shaunyp in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
CAR WONT START
i recently changed what i thought was the relay for the heater blower, but, the only reason it wasnt working was the earth wire wasnt connected, so i connected it and the blower works perfect. My problem now is the car turns over but wont fire, i hear a clicking noise from the relays when i turn key, should i check relay to see if i have put it in right way round? or change the one that is making clicking noise?
Thanks.
![Yomp in the usergroup ‘Paid Member’ Yomp in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Yomp in the usergroup ‘Local hero’ Yomp in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Sounds like it could be a voltage drop causing a relay to drop in and out not the relay itself. Could be something pulling too many amps during cranking or excessive resistance in wires.
![golfcabrio in the usergroup ‘Moderators’ golfcabrio in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![golfcabrio in the usergroup ‘Local hero’ golfcabrio in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Did you put the old relay back and then try to start it?
![001.JPG 001.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1508058319/uploads/attachments/59e324cda030d.jpg)
Won't Crank over?
Will Crank over but not fire?
Check all the connectors around where you were working chances are you knocked something loose. Wouldn't be the first case of self-inflicted difficulty.
Won't crank, look at your Frame to Engine grounds and your Batter to frame grounds.
Verify that your starter solenoid is engaging….
You can place the car in Neutral, Parking brake set.
Turn the Keys to the first click, then Jumper the starter solenoid to Positive battery, of the engine spins, then you are looking at a bad ignition switch or feed wire from it to the starter.
If the starter doesn't spin, take a Battery jumper from the Negative Post and Clip it to the engine. If the engine turns over when you jump the solenoid wire. Bad Ground, if it doesn't then bad starter solenoid or bad starter.
If the car starts the fuel pump relay is dead and you need to fix or replace the fuel pump relay.
Thanks for all replies, i replaced blown #5, 15 amp fuse still no joy so, i bought a new fuel pump relay #62. hey presto car started 1st time. Happy days.
Thanks guys.
shaunyp said
Hi all.
Thanks guys.
Buy another and throw it in the boot or glove box, they tend to go bad at the oddest times ie: middle of a rain store. Running late for a wedding…
I've now got a spare as when I put my old relay back in it worked fine and has for the last 2 years….. very strange…..
