Car stuck accelerating
(In Topic #244832)
If the Cable is free, as you can take it off and the cable moves in and out freely then your issue may be with the cold start injector or WUR.
Of course you want to check and eliminate vacuum leaks.
Will look into the warm up regulator and I've changed the other 4 injectors but never the cold star injector I reckon it's never been changed and the car has 180k miles.
Will have a look into this weekend and see what I can find. How can I rule out the WUR from being faulty ?
Diesels and Digifant I know…cis not so much.
Note: After starting the car multiple times the revs stop at 3500-4000rpm and the problem happened all of a sudden after a bit of acceleration in 2nd gear at 4000rpm went to neutral to go into 3rd gear and then realised while in neutral car was revving for no reason
Just out of curiosity looked at the oil dipstick and it did smell a bit petroly. Gonna have another look tomorrow after work and just check the idle screw on the back of the throttle body to see if something is wrong (loose or rubber seal gone bad). If i can't find anything there, then might look into buying another injector for the cold start. I only know heritage parts so if anyone else has any good websites for buying golf parts that would be a great help.
But on the other hand after inspecting and removing a load of pipes because they seemed dirty as if they were leaking I found this. Gonna order the parts and hopefully it should resolve the issue 🤞
Don't forget to test the rear of the throttle body there is a 7mm brass screw if it turns easily with your fingers the o-ring s bad. Gimmee Wrap the Treads of the thing only the threads with Teflon tape.
Remember to wrape the threads with teflon tape.
place it back in, tighten it till it stops then back off about 3/4 turn.
Jon Hodgon said
What is the green connector hooked up to on the front of the throttle body? I have the same on mine but nothing is plugged into it…
The car's idle is still 4000rpm which I doubt is because of air leaks now and more because something is stuck or open when it shouldn't be. Note that this happened while driving after a little acceleration at 4000-5000ish rpm.
Throttle flap is fine and free, the air flap above air filter is also free and moves by hand. The cold start injector when electrical connector is disconnected car struggles but eventually starts leading me to rule that out because if stuck open mechanically it would have been the same plugged or unplugged.
It's too dark to work now.
(Idea : Tomorrow will wind in the idle screw to the max and see if car starts, if the car manages to start then would that mean that it's getting air from somewhere else ??) Let me know if the idea is sound or pointless.
If anyone has any ideas let me know I'm all ears !
This is my very first project car btw so I'm new to the whole car world and a complete beginner. Car did run excellent last year FYI
Jon Hodgon said
Off the back of my head i can't remember what the green connector plugs into. I should receive the new 3 way hose I need tomorrow so I'll take a look while I'm there at my garage and let you know
Thanks - looks like it could be a throttle position sensor, I have the same on mine but the throttle body is from an audi 80 and there isn't anything standard on the mk1 engine to plug it into as far as I'm aware, so would be interesting to see how yours is set up…
Tightening the idle screw didn't do anything because my car isn't idling but instantly accelerating so car doesn't get a chance to idle
Just an idea could my k jetronic system be faulty ???
Forcing my injectors to spray as if accelerating when they shouldn't be ?
Hope you sort your issue
K-jet is relatively simple in the principles of it's operation - as the throttle opens, more air is pulled past the air-flow plate, which in turn moves a small piston in the metering head to allow more fuel to the injectors. Vacuum leaks normally admit 'unmetered air' that is to say it has no impact on the air flow plate position, so you'd end up with a leaner mixture as you'll have more air than fuel.
On the back of the inlet manifold you'll find the Auxiallary air valve (AAV), this allows metered air past the throttle body on cold starts (it's basically a flap is open when cold and closes as the car warms up). If this is stuck open, it could be the issue.
Clamp the hose that comes out of the AAV (will come at the back of the inlet manifold, left hand side as you are facing the car, if you stand to the left of the engine you'll see it clearly) and see if that makes any difference.
Your problem must be to do with an air leak, excess fuel would slow the engine down, what about the hose that goes to the brake servo, are the brakes okay
There are some one way valves in the system as well but I confess I don't fully understand how all that works.
