Car cutting out under acceleration
(In Topic #221219)
What did your mechanic do?
It could be rust in the fuel tank blocking the flow of fuel.
It could the fuel pump is on it's way out and might not be able to pump enough fuel at higher rpm's to give the engine the fuel it needs under load.
Could be the timing needs adjusting as the spark is being given at the wrong time.
Could be a lack of air.
Have a look at the air filter and fuel filters first. Easy to check and cheap to replace. I'm assuming it's a carb model.
Check the dizzy and the rotor arm for damage and wear as these may need replacing.
Check the spark plugs too. Check the colour of the ends to see if it's running rich or lean.
Report back with your findings and we might be a ble to advise a bit more.
Ian
