Can't find the right pipe
(In Topic #222766)
Water pipe
Hi guys
I'm looking for a water pipe for my 85 mk1 gti cabby and can't seem to find it.
Part number is 027121065A
I can find 027121065D VW heritage but thats for a mk2
Thanks in advance
Thanks in advance
Regional Host NE
is that the one with the heater valve
on the end mate
on the end mate
Hi mate
Yes I'm sure it is, the valve site in the middle of 2 rubber hoses before it goes through the bulkhead?
Regional Host NE
sure i have a couple will look in
the morning and get back to you
Cheers mate that would be good
Regional Host NE
hi mate they are not the best either
Thanks for looking mate, the hunt continues.👍🏻
There are others online but can't seem to hunt down the part number ending in A
This is the one I got for my 83 GTI, doesn't have an A at the end of part number but says fits the 1.8 , was perfect in mine.
https://www.classic-vw.co.uk/mk1-golf-metal-coolant-pipe-15-16-18-including-diesel-027151065-5004-p.asp
On my Mk2 Scirocco I've changed it for the Mk2 Golf version. It's a slightly larger diameter pipe and the fixings are slightly different. You cab cut some of the fixings off the old pipe and move them over.
Thanks mate, looking at it there seems to be 3 ends the one I removed only had 2
You can buy a rubber cap and cap off the end that you don't want or:
Remake a new out of thick wall copper pipe, and solder the connections that you require, you can flare the ends so that they take the hoses or solder on barbed fittings to hold the hoses as well. Where the pipe attached to the flanges you can use Steel, and have it silver soldered to the pipe…
