Can't adjust brake pedal height
(In Topic #215038)
POS repair (Previous Owners Service).
Also since I see a MC push rod that appears to be sagging, I would suspect that you may have an issue with the bushing or pin that the pedals pivot on. I would think about taking a look at the pedal assembly and bushings.
pictured return spring goes in the bin, the only spring it should have is on brake servo
see clutch stop here:
rubjonny said
ignore the screwdriver and massive rust hole, concentrate on plastic clip in the foreground
